TANNERS said:also have you bonded your boiler ,and main gas, and water, within 300mm of the point of entry to the house, before any t's![]()
garythekitchenfitter said:No disrespect to the other guys but the reg book quotes "supplementary bonding is not required to metal parts supplied by plastic pipes, such as metal hot and cold water taps supplied from plastic pipes. A metal bath not connected to extraneous-conductive-parts (such as structural steel work). With plastic hot and cold water pipes and plastic waste pipes does not require supplementary bonding. supplementary bonding in a bathroom or shower room will still be required between the protective conductors of circuits supplying class 1 and class 2 equipment in the zones eg. heaters showers and accessible luminaires."
TANNERS said:ALL extraneous CONDUCTIVE PARTS MUST BE BONDED TO THE MAIN EARTHING CONDUCTOR
therefore all metalwork in the bathroom should be bonded
the way i look at it,is if a potential was raised on say the hot tap , it would be live , yes
you touch it create a circuit
if it is bonded the current would flow through the bonding straps/earth cable to earth causing the overcurrent device would operate eliminating the potential
