Hello all,
Help! Yesterday morning I woke up to find no hot water. I have an Economy 7 water tank fitted with two immersion heaters, one at the bottom of the tank and one about halfway up. The lower heater is wired to a circuit which is only live during cheap rate, and the upper is wired on a normal circuit which is live all the time. I believe all this is fairly standard.
The upper heater works fine but of course it only heats up half the tank.
I've tried wiring the lower heater up with the lead to the upper one, but it still didn't get hot. I've removed the thermostat that sits in the lower element and tested it with a continuity tester and a jug of hot water, and it seems to work fine. Whilst the lower heater was wired up with the live circuit for the top-up heater, both sides of the thermostat were live when tested with a voltmeter, so power is definitely getting to the element.
Would I be right in thinking it's a new immersion heater required? There's a datestamp on the water cylinder of May 2003 so it seems very early to have failed, though the water is pretty hard here. The other reason I'm a little suspicious is that both elements have the same resistance when checked with an ohmmeter, so there's obviously still a full circuit through the element.
Any ideas would be very much appreciated!
Cheers
Mike
Cheers
Mike
