    Dismiss Notice
Eek - my copper pipes have melted away!
Discussion in 'Plumbing and Central Heating' started by SnakeyB, 25 Sep 2021.
  1. SnakeyB
    SnakeyB
    16 Feb 2020
    12
    Thanks Received:
    Country:
    I don't have a water tank so I guess yes it is mains pressure. If you do a quick search for my previous posts (one thread from a couple of years ago) there are some photos there of the boiler which I think is a combi.
    OK then I definitely won't get the scourer out in case that's the straw that breaks the camel's back. Also scared now that the stopcock will come off in my hand!
    I suppose now we get to the interesting question: if I have no local recommendations, what's the best way to find a plumber? Still, at least I am armed with some helpful information so he can't suck his teeth and tell me that I need a whole new central heating system and I'll believe him :D.
  2. Sponsored Links
  3. ETAF
    ETAF
    24 Apr 2008
    1,091
    Thanks Received:
    196
    UK, Wittering, West Sussex
    Country:
    you could signup to your local nextdoor.com and see what recommendations they have - from people who have used them , i often see that locally and contribute.
    But you will see the same names keep coming up frequently , and i know of 3 good plumbers down my way , and they all often get mentioned
    you can also then maybe look at checkatrade , BUT be careful of that , i have had some cowboys turn-up here for jobs from checkatrade useless sometimes,
    the plumbers i mentioned are not even on checkatrade , they have to much work locally
    BUt the guy who has replaced all our doors and windows over several years , gets a lot of work via checkatrade
    I would not use the mybuilder and other sites personally
  4. terryplumb
    terryplumb
    8 May 2017
    6,011
    Thanks Received:
    1,247
    Country:
    Do your flats have a management company for communal issues ,if so they may have a plumber they use. Failing recommendations from friends ,neighbours ,family etc ,go for a long established company.
    • Thanks Thanks x 1
  5. ianmcd
    ianmcd
    15 Aug 2010
    22,802
    Thanks Received:
    9,213
    Lanarkshire
    Country:
    if you go to the top of this page and click on "Local" you put your postcode in and can search for members from here that cover your area , if they have signed up, I would avoid checkatrade and the likes, they are bottom feeders
    • Thanks Thanks x 1
  6. CBW
    CBW
    26 Sep 2019
    8,472
    Thanks Received:
    2,223
    North
    Country:
    Yep, that or put your location ;)
    • Thanks Thanks x 1
    • Like Like x 1
  7. SnakeyB
    SnakeyB
    16 Feb 2020
    12
    Thanks Received:
    Country:
    Central London. I might see if my old landlord knows someone, he has a lot of properties in this area.
    • Like Like x 1
  8. Sponsored Links
  9. Keithmac
    Keithmac
    10 Oct 2017
    2,126
    Thanks Received:
    338
    Country:
    It's odd how there's no water marks or staining around where they've let go?.
    • Thanks Thanks x 1
  10. SnakeyB
    SnakeyB
    16 Feb 2020
    12
    Thanks Received:
    Country:
    Well the engineer was equally mystified as to what could have caused it, so I guess we're going with "probably something to do with whatever you spilled on it" but he was able to fix it in about an hour (and he's going to bring some lagging round when he comes back at the weekend to do the magnaclean etc, in case of future spillages although I've totally learned my lesson there...).
    He said the hot water pipe was fine when he cleaned the stuff off it - so if my next thread is titled "Aargh - I've just got out of the shower to find the flat ankle-deep in hot water!" then at least I'll have someone to phone about it!
    In the meantime, thank you everyone for the reassurance, suggestions etc, I really appreciate it.
    • Thanks Thanks x 1
    • Like Like x 1
  11. terryplumb
    terryplumb
    8 May 2017
    6,011
    Thanks Received:
    1,247
    Country:
    Thanks for letting us know ,glad your sorted.
    • Like Like x 1
  12. opps
    opps
    16 Jun 2006
    5,077
    Thanks Received:
    809
    London
    Country:
    Am I being superdense here?
    The two pipes with holes in them, what were they supplying and why was no water visible elsewhere.
    I did once make the mistake of using the black Harpic in a basin. It wore away the chrome finish on the waste. It didn't damage the brass though. The instructions said do not use on stainless steel urinals. My basin is isn't stainless steel, and I have never pee'd in it. I contacted Harpic, they didn't care. I tried to suggest that it might have been more helpful to warn customers that their product might corrode metals, again they didn't care. I now use different products...
    • Like Like x 1
  13. CBW
    CBW
    26 Sep 2019
    8,472
    Thanks Received:
    2,223
    North
    Country:
    One is likely the safety discharge pipe (aka blow off), other could be a dead feed or isolated.
    • Like Like x 1
  14. SnakeyB
    SnakeyB
    16 Feb 2020
    12
    Thanks Received:
    Country:
    Central heating pipes - or at least, that's what I told the guy they were and he didn't laugh and say "no they're not!" - and no idea why the downstairs neighbours didn't run up to me back whenever it happened, screaming that their flat was flooding. Engineer says in buildings like this the water could have gone anywhere before going downwards and it's possible that it ended up coming through down the void space behind the boiler or something rather than through the ceiling directly above their kitchen sink.
    The boiler happily fired up as soon as the pipes were fixed and the system was refilled so there wasn't anything wrong with it apart from there being no water in the system. Last night was a quick fix and he's coming back round at the weekend to put chemicals in and do the magnaclean, so I might ask him to tell me more about it then. (The disproportionate level of terror I feel when anything goes wrong involving gas, electricity or water sort of embarrasses me, so it would be handy to learn more about this stuff generally.)
    • Like Like x 2
Loading...
Share This Page
