Hello All. I would really appreciate some input on something. I'm installing a 9Kw electric boiler - and am upgrading my old school Wylex re-wireable fused CU's with something more modern. The current (inherited) setup is pretty chaotic - with a 6 way CU and another 2 way CU both running from an 80A 30mA RCD (Primary Earth conection is TN-S). Existing circuits are 4x15A, (2 15A on the 2way CU) 1x5A, 1x20A and 2x30A . My main question is this - the required 40A supply for the boiler - would this be best served from a CU+RCD totally separate from the new CU and existing RCD setup - it's a pretty big load and in theory could overload the 80A shared/common RCD - or should I strip out the existing main RCD - use a split load CU and run the boiler circuit from the non RCD side of the CU but through an RCBO?
Or just move somewhere on gas
Your thoughts very much appreciated.
