Electric shower
O
oompah
If I install a electric shower in a downstairs cloakroom can i take the power supply from the ring with a fused spur or do I need to wire it completely seperate. :LOL:
5 May 2007
Its probably easier to run it separate if the consumer unit is there in the cloakroom
PS don't forget the the label warning of 2 different wire colours :D
O
oompah
No the consumer unit is away from the cloakroom about 7 yards. :LOL:
16 Feb 2007
West Midlands
oh good gods..
a shower takes more power than a ring can supply..
you will need to run 10mm² cable back to the CU and install a suitable MCB and RCD ( or RCBO which combines both into one. )
this is notifiable work as a shower makes it a bathroom and is covered by Part P of the building regulations..
you need to tell your local authority building control IN ADVANCE of starting the work..
might just be easier and cheaper in the long run to get a qualified and part P registered electrician in..
also, lazygit, if it's a cloakroom then the CU had better not be in there because it sure as hell would be in the zones..
O
oompah
ColJack said:
oh good gods..
Thankyou I didn`t think it would be that easy.
21 Oct 2004
Tip: when you don't have the slightest, foggiest, slimmest, tiniest, faintest, most tenuous grasp of the subject you're advising on, then it's time to shut up.
1 May 2006
should'nt it be confirmed first that its a electric shower rather then a power shower :rolleyes:
16 Feb 2007
West Midlands
electric shower stated, not shower pump etc, so the advice given was based on that..
O
oompah
definitely a electric shower, to far from hot water tank .
O
oompah
So what do you think is the best idea?
O
oompah
21 Oct 2004
WTF?
ColJack has already told you everything you need to know and do - why are you still asking? :!:
O
oompah
Softus said:
WTF?
How do you know its everthing i need to know?
5 May 2007
Dude, I was taking the p155 because the I found the spur issue funny. :rolleyes:
