electric showers
6 Jun 2007
Worcestershire
i have electric shower coming off rising main in the loft there are no tanks or emersion tank i have combi boiler does the feed pipe 2 the shower in the loft need to be a certain height above the shower the water pressure is low the 15mm feed pipe is at present 30cm above shower unit will this cause the low pressure fault thankyou
Low pressure will only be caused if the incoming mains pressure is too low, not because it is 30cm above the shower ;)
