Hi All
I've had some really good advice from the Plumbers about installing a shower.
I have reposted their responses below, 'cos the final question is more electrical, and is concerned about connecting an "all in one" shower unit (pump and controls in one wall mounted box). Is my thinking correct that I can use something like Screwfix 14770 to connect via a mains spur in the landing airing cupboard?
View previous topic :: View next topic
Author Message
RKB
Posted: Mon Jan 10, 2005 8:59 pm Post Subject: installing a shower
Been asked to install a shower in mother in laws.
System is a none combi, with cold feed from loft tank (so hot and cold at same pressure).
If I was to recommend a good thermostatic mixer (any recommendations?), could I just not tee off existing hot and cold supplies in bathroom?
Or do I have to get involved with essex flanges?
Thanks.
Back to top Alert Moderators
ArtfulBodger
Posted: Mon Jan 10, 2005 9:04 pm Post Subject:
Yes you do, but only if you want to do it properly oh and don't forget the new suply from the cold cistern
RKB
Posted: Mon Jan 10, 2005 9:12 pm Post Subject:
Thanks Artful,
Can you explain the "new supply from the cold cistern"?
kevplumb
Posted: Mon Jan 10, 2005 9:46 pm Post Subject:
you need to balance the feed pressure so normally shower has its own supply from the head tank feeding the cylinder
__________________
all work is guaranteed till the cheque clears
RKB
Posted: Mon Jan 10, 2005 10:14 pm Post Subject:
Hi Kevplumb,
OK, I understand the reasoning.
What is thge best way to connect a supply from the cylinder feed tank? Do you actually tap into the tank (is there a fitting to do that?), or feed off the line out of the tank to the cylinder, i.e. into the existing pipe?
Thanks..
kevplumb
Posted: Mon Jan 10, 2005 10:18 pm Post Subject:
tap into the tank preff lower than where the cylinder feed comes out
hot runs out first
__________________
RKB
Posted: Mon Jan 10, 2005 10:35 pm Post Subject:
Understand..
Thanks Kev
ChrisR
Posted: Tue Jan 11, 2005 12:29 am Post Subject:
If it's from the loft to the floor below, you'll have a piddling shower unless you pump it. Easiest is probably a pumped box-on-the-wall like an Aqualisa Aquastream (£300+) or a Mira (£less) or a NewTeam (£130?)
kevplumb
Posted: Tue Jan 11, 2005 12:31 am Post Subject:
have they sorted the newteams out now
they used to be a g*t for springing leaks
__________________
RKB
Posted: Tue Jan 11, 2005 1:01 am Post Subject:
Thanks for the suggestions.
If I was to go with an "all in one" solution, which was mains driven, would I need to get a sparks in to install it on a dedicated RCD at the CU. Or can they run of a spurred FCU /RCD, so in the airing cupboard on the landing?
Author Message
RKB
Thanks.
ArtfulBodger
RKB
Thanks Artful,
kevplumb
__________________
RKB
Hi Kevplumb,
Thanks..
kevplumb
hot runs out first
__________________
RKB
Understand..
Thanks Kev
ChrisR
kevplumb
__________________
RKB
