Elmdene Rapier 6000 connections
3 Aug 2012
Hi all.
I've been searching everywhere for this and ended up in this forum. :)
I have a Gira KNX alarm system and I need help connecting it to a Elmdene Rapier 6000 external siren.
It seems I can't attach files to the post so I have to leave a link to the alarm manual: (I didn't find any online manual for the rapier 6000)
http://descargas.futurasmus-knxgroup.org/DOC/ES/BERKER/333/75730010.pdf
This is how I connected them:
Elmdene - Gira
1 (H+) - 12v/ 0,1A (I have doubts on this)
2 (H-) - 12v/ 0,1A GND (I have doubts on this)
3 (RTN) - don't know where to connect
4 (-ST) - Blitz (-)
5 (-R) - ASIR (-)
When I connect like this everything works, but:
- Don't know where to connect the tamper return (RTN)
- The light strobe is very dimm (you almost can't tell it's strobing)
so,
Am I connecting the + and - to the wrong place?
Where shall I connect RTN?
The siren is rated 250ma and the strobe 150ma. The Gira external 12v makes reference to only 100ma power. Can it be a low power issue?
I still haven't cut the engineer link on the siren (makes siren act for 5 seconds max.). Does it have anything to do with it?
Any help would be appreciated.
Thanks!
Had a look at your manual doesnt look like you have a Tamp Return in the panel. Is it required ?
You could connect it to a zone with a wire loop and program it too suit if possible, so when the neg is removed it will trigger that zone, it would need programming as a 24hr zone
I have only done the above with a 12v going to 0v and it worked ok
Doherty1234,
Thanks for your reply. No, I don't need tamper return. That is the least of my concerns. My main problem is why is the strobe so dimm. You almost can't see it in daylight. Is it normal?
Hi MikeMelga,
I am not sure about the brightness of the strobe as this differs with diffrent manufacturers, If it can be seen at night i wouldnt worry too much
But if its still dim you could wire in some Blue 12v LEDs. Connect the + to the + hold off & connect the Neg - to your strobe trigger
I put some Blue LEDs in a bell box but they are connected to the hold off supply so they are constantly illuminated looks really smart at night
You can't adjust the strobe, the trigger voltage is pre-set. Maybe Bernard has a trick or two.
