Euramo MX 130A CH Pump replacement.....
25 Jan 2005
Hi there,
I have a Euramo-MX-130-A Pump which now leaks and currently trying to replace (bearings gone). Howver i have looked over the net and cant find any info on it whatsoever !! I am after the duty that it can do. I have a spare Grundfos UP20-15N 150 pump which i was wondering if i could use. Obviously the flange sizes are different (typical) so will have to deal with this !!
The system is a pumped type with separate F&E tank for hot water and a separate cold water tank.
Basically just wondering if i could use this pump or if anyone has any info on the original Euramo pump. Model MX130/180 reads on the electrics cover.
Sorry if i've not given all the info necessary, just ask and i will try to answer.
Regards
hi reply to question about EURAMO MXL130-180
Hydraulic performance
position 1. 6m3/h @ 2.1m
position 2. 2.5m3/m @ 3.4m
position 3. 3.5 m3/h @ 4.3m
hope this helps
