Extending pipework to plumb a washing machine in an outhouse
7 Jul 2005
Hi there - !st post so easy now ;)
I have just built a wooden shed about 12 ft from my kitchen window with the idea of putting the washing machine in it
The electrics are all sorted but I basically need to bring the pipework from under the sink , under the house floor, out across a concrete yard and up into the shed to the machine
I have researched a little and was planning to come off the original T's which feed the hot and cold to the machine and run into Hep 2 O pipe and bring this out into a track in the yard and up into the shed
Is there any simple method you can recommend and anything in particular I should or should not do?
Thanks for any future help and remember I aint a professional so treat me as such if you could :LOL:
Cheers
7 Jul 2005
Thanks Kev - any advice on the connection side of things - ie going from 15 mm copper to Hep 2 O and back up again is no bother surely ?
Cheers
ps - Shed is fully insulated with 50mm polystyrene and 3/8 exterior ply
Any advice on the type of insulation for the pipework under the concrete?
7 Jul 2005
sorry to be an arse but isn't there a speedfit fitting which will connect the washing machine hose type fitting on the copper T to a Hep 2 O pipe (15mm as well I presume or is 22 better?)
This would avoid compression fittings ?
Ta
7 Jul 2005
Yes that was a ****tesque question lol
What I meant to refer to was that I think I have seen a speedfit appliance tap which can connect directly into the valve of the T then run into a Hep 2 O pipe - or is this nonsense?
Is 15 mm Hep the optimum?
Remember - You need us thickos to feel important
;) ;) :oops:
24 Jul 2003
London
You can get Speedfit isolating valves, sure. The all plastic ones don't last long at all though - the screwdriver slot gets chewed. Use a normal stop cock. Compression is very easy to do!
DOing what you want would be against the regs in England! You could just provide an outside tap and screw a normal WM hose onto that - 3/4" thread. Then in winter you keep the hose indoors!
