    Dismiss Notice
Faulty Karcher K620 Pressure Washer.
Discussion in 'Appliances' started by macmini, 12 Jan 2006.
  1. macmini
    macmini
    12 Jan 2006
    154
    Thanks Received:
    Yorkshire
    Country:
    Had this a couple of years and it's always been fine, until today, i came to use it after it'd been stood for the winter (in a heated garage, so no frost or water damage), at first it tripped the RCD, thought nothing of it and reset it, stayed on this time, however, the pressure washer is completely dead, with the exception of the green power LED. This is lit.
    I then disconnected it and checked all connections, when i reconnected it, the RCD didn't trip but now the unit is completely dead.
    Any ideas as to what to check?
    I'm quite competent at repairing things, just not had chance to have a good look at it yet (had to wash the bike by hand!), is there anything in particular i should look out for?
    Thanks in advance!
  2. Sponsored Links
  3. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    throw it away and get a new one :( i think they are a "sealed unit" (may be wrong) but unless its something like a loose connection its probably going to be expensive
    I once had one give up, although i think it was due to frost, i neverbothered and got a new one, which was better than the 1st one and cost less
  4. macmini
    macmini
    12 Jan 2006
    154
    Thanks Received:
    Yorkshire
    Country:
    I'm not too sure whether it's sealed or not, not had a proper look but i can see a few screws around the casing!
    It's annoying, this cost over £300 about 3yrs ago and has barely had any use.
    Grrr.
    Cheers anyway.
  5. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    well it wouln't do any harm to open the screws but i think its the idsides that are sealed, but never having opened one i may be wrong, mine was about £140, new one just under £100, but there can be no harm in trying, as i said you may find a loose wire.
    i also have a cheapo pillar drill, the on / off relay went, a 1.20 switch cured that. I am not saying dont look, just dont hold your hopes too high.
    never know i may be totaly wrong. good luck though
  6. macmini
    macmini
    12 Jan 2006
    154
    Thanks Received:
    Yorkshire
    Country:
    Cheers,
    I think i'll wait for the weather to get a little warmer first though!
    Too cold to be working outside.
    I'll let you know how it goes.
  7. Sponsored Links
  8. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    why work out side, after all you did say
  9. macmini
    macmini
    12 Jan 2006
    154
    Thanks Received:
    Yorkshire
    Country:
    you know what i mean, it's heated, in the fact that it's not freezing.
    it's about 8oC in there i think, but, with the weather as it is, i'll wait until there's a nice day!
    Cheers for all your help.
  10. racket
    racket
    16 Apr 2004
    218
    Thanks Received:
    Cheshire
    Country:
    I had the same problem with mine when I came to use it last time. I took all the casing off and the only thing that controls the motor is a micro switch controlled by a plunger that measures the pressure differential across the pump. I found that the plunger was sticking due to the grease on the plunger had gone bad and was sticky. I cleaned the plunger and
    re-greased it, it now works fine :LOL: hope this helps.
  11. macmini
    macmini
    12 Jan 2006
    154
    Thanks Received:
    Yorkshire
    Country:
    Thanks for that!
    I'll give it a check.
  12. jetwashking
    jetwashking
    18 Apr 2009
    12
    Thanks Received:
    Country:
    hello i fix karchers and the k620m will stop working due to lack of use. the pump is aluminium and will rust if left unused for long periods. the rust is aluminiumoxide and is a white powder. the answer is to use the machine at least every 8 wks. the repair is to clean and grease the control piston on the top of the pump. i hope to post a how to video on youtube soon. search "repair the k620m" on youtube. If your piston has stuck the best solution is a new piston and grease. always use silicone grease as it is not washed away by the water. sparesgiant sell the control piston online part number 4580347.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
