FCU on ring main - need to supply oven + hob ignition
29 Sep 2009
London
I have an 13 amp FCU on the ring main, however I need to connect a single electric oven and the ignition for a gas hob - and doh :oops: the supply was forgotten for that (won't happen again).
Initial thoughts
- run the oven of load side of 13amp FCU and then run a spur of the supply on the FCU to a socket/FCU for the 3amp ignition or maybe the other way around.
Has anybody got any other ways that it could be done, apart from extending the ring
Cheers
Flash
If you do it the other way around then the oven will be on a 3A fuse - not good.
1st way would work, or you could replace the FCU with a twin socket outlet.
Cheers ban-all-sheds - I should have stated that I the fuses would be changing accordingly. Just wondered if there was another way around it, as this way one FCU would be above worktop and the other one below.
How about changing the FCU to a 20A double-pole isolator switch above the counter feeding a double-gang socket below the counter?
