Ferroli Modena 80 boiler - thermostat valves rattle
  • Thread starter Thread starter hogpog
  • Start date Start date
H
hogpog
hi, just had above boiler fitted. all 3 downstairs rads also had new pettinaroli thermostat valves, the upstairs 2 have the existing honeywell thermostat valves.
after central heating has been on for a while the upstairs rads begin to vibrate and rattle, it sounds almost as if someone is drilling into a wall. i've discovered that by turning down the thermostat valves the rattling/vibrating eventually stops. also by turning on a hot water tap either in the kitchen or upstairs bathroom this also temporarily stops the noise. it's as though the noise starts once the rads reach a certain temperature.
i thought the central heating system and kitchen/bathroom tap water systems were separate, so how can turning on a tap stop a radiator from being noisy ?
is it the older honeywell thermostat valves on the upstairs rads ? anyone offer any advice ?
thanks
p.s. when the central heating is on and the boiler is pumping hot water around the radiator system, if i turn on a tap the central heating seems to stop, the boiler switches from central heating mode to hot water mode. is this normal ?
the flow and return have been swapped when you had the new boiler popped in, chances are the TRV's are a bit old and will not work if fitted on the return side
call they chaps who fitted the boiler back
i'll call him in the morning. do you mean that in effect the direction of the hot water through the rad system has been reversed ? that the first rad is now the last ?
not really, if you look a the valves you will ses an arrow this is the way the water should flow through the valve, if the rads are cold turn the heat on and you will find the heat comes through the valve at the other end against the flow
new trv are bi directional (supposidly) and this dont happen
i'll quote "bi-directional trv" and "flow and return" tomorrow to the boiler man.
i'm very impressed with this forum - instant info & help = excellent
