Hi all.
My ferroli falcon 2 started playing up a few days ago. for both hot water and heating it would fire up for about 5 seconds then stop, it would then fire up again then approx 5 seconds later it would stop. It would repeat this continuously.
I had re-tried the boiler over the last few days with the same result.
Today i tried it again with the same result. For some reason i decided to pull out one of the 80mm blanking plates off the top of the boiler (see page 16 of the manual). the blanking plates are there to block up hole intended for if the boiler is fit with a seperate outlet and inlet pipe as opposed to a single pipe that does both, i believe. The boiler will now stay lit for 6 mins approx before turning off for a few mins then firing back up. this cycle continues.
Any ideas what could be wrong?
thanks.
thanks.
