Fibreglass flat roof
8 Nov 2005
Caithness
Hi All
Checking my flat roof has shown some patches that are starting to peel back and crack. This is only the top surface. Apart from that, it seems very sound. I want to tidy up the whole roof so what should I use???
Bitumen or special fibreglass resin coat etc.
Any help appreciated
Steve
I was considering using fiberglass to replace the damaged flat roof felt on my garage flat roof but was a bit shocked at the expense. I looked into flat roofing materials and found EPDM flat roof membrane for me to be the better option, plus you can install this flat roof system DIY. Did it myself and was surprised at the ease of fitting helped with the informative DVD supplied.
See www.rubbershield.co.uk
This page helped me decide which system to go for (I'll let you work it out).
[advertising link removed, mod 9]
Gives a pretty detailed explanation of the pros and cons of both.
