Finishing the roof?
12 Nov 2013
Nottinghamshire
Sorry if this is a dumb question, but i'm intending to install a lean to roof on a small extension using concrete interlocking tiles.
I'm aware that i'll require tiles and 1.5 tiles on the side where I'm starting, but how do I finish the other end as it's not forced to fall on a full tile etc.
What's the correct process for finishing tiles in this situation?
Any help appreciated.
Large format concrete tiles are nearly 300mm wide so set you roof out accordingly 2"3"4" verge then cutting one tile in half should work for both ends, you can also buy continuous dry verges to fit at the ends
