Fireplace (wall/surround) removal
10 May 2005
London
Hi
I'm an absolute newbie at DIY (as I'm sure the following passage will tell), and I need help in understanding the work involved in the following:
The living room of the new house I bought has a gas heater mounted on a wall in the living room. The heater is mounted at what I'm assuming is called a fireplace surround (it is a protrusion of about 10 inches from the living room wall). There is no chimney.
As part of my redecoration plans, I want to get rid of that entire structure - the heater and the protruding wall.
1. Will I need planning permission for that?
2. I have been quoted about a £1000 pounds for the removal and subsequent restoration (plastering, flooring, etc). Is that reasonable?
Many Thanks
M
_______________
moderator
please note 9 :wink:
get someone corgi registered to move your gas then get a plasterer to give you a price for making good, are you sure theres no chimney or vent.
Thanks jbonding
And thanks for pointing that one out admin, will remember it :)
Could be a flueless appliance you have there. Check the Make/model number of iton the net or with manufacturer. If it is flueless you must have ventilation usually 50cm² at both high and low positions > Total 100cm².
If it isnt flueless and you do not have a chimney or flue then it could be an illegal and more to the point a dangerous installation. Get it checked out if you plan to use it in the meantime
