Flame Fault
W
WSDLTD
I'm having a problem with a boiler at the minute, and what is happening is the boiler flame went out so it was reset and re-light and the boiler fired up for the central heating to work, but then upon turning the tap on for the hot water the flame went out again. i have tried a few times to re-light it and it does but as soon as the water comes on the flame goes again
any ideas anyone please??
kevplumb said:
i'm having problems with a boiler at the moment
it won't heat the rads when the hot water is running
Sorry to hijack the topic, but I'm getting exactly the same problem with my fuel-burning appliance.
Is your boiler the same make and model as mine?
Also, the system makes a noise - what could be the cause of that?
If doesn't do it all the time, only sometimes, i.e. only when I do certain things. :confused:
I take it its a combi. How about the DHW heat exchanger scaled up, boiler going to overheat when taps turned on? Is diverter valve moving ok?
No it isn't a combi, it's white, and in a box on the wall. It's got pipes.
