Flamin' flush cones!!!
14 Jan 2008
Staffordshire
Need to replace pan, hence the problem.
High level victorian-style, 35mm od chromed flush pipe, now having to feed into modern Twyford pan.
Internal flush cone (and B & Q replacement) say "for 40mm pipe".
Obviously then, when I put it all together and tested it, it p!ssed out on flushing.
Would I be better just sacking off the chromed down pipe, and replacing with modern white plastic 40mm flush pipe?
(Already tried silicone-ing it, which was not effective).
I hate anything to do with water.............
Awkward as its essential to life :ROFLMAO:
I would try wrapping ptfe tape around the end of the pipe before putting the flush cone on, first... Make the pipe o/d bigger until it's watertight... It's all easily accessible with the setup you have... Try a partial flush rather than full flush when testing - this is possible with a slight pull of the lever/chain.
Oh... Missed that it was 35mm needing to be 40mm...
That would be a lot of ptfe :)
Go with Dan's link :whistle:
Tried the different flush cone - no joy....
So, I bought a standard pe flush pipe (40mm), cut a three inch length piece off it, and jammed it (with silicone) over the end of the 35mm original.
Bunged it all back together, and it appears to have worked!
Hallelujah(y)
