hi, my Philco WD 1109 SE let out a loud pop and went dead shortly after putting it on a normal wash cycle. i changed the fuse in the plug and took the top and back off and again switched it on to a normal cycle. it 'popped' again and a flash came from the area to the right (your right as you look at the back of the machine) of the motor - approximately where the live wire connects to the outer drum. it doesn't seem to pop when the dryer is used (i've put another fuse in the plug).
if it would help anybody's diagnosis of this i did take a video clip of the back of the machine as it blew. any help would be appreciated!
