Fitting a bathroom suite and for ease of pipework I wish to use 500mm long flexbile tap connectors (the mixer is in the centre of the bath at the back wall)
I require two no. both with 3/4' bsp at one end to to suit the bath mixer, one with 15mm and the other with 22mm at the other end to suit the cold and hot pipework.
My concern is that the flexi connectors I have seen (scewfix) both have a bores of 10mm. I don't think this will be a problem on the cold feed but will this have a an effect on the 22mm hot supply, i.e. will the water feeding the bath be unduly restricted with such a reduction between the sizes. My heating system is combi (28kw I think)
Many thanks,
Many thanks,
