Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
They seem to come in minimum lengths of 300mm, with 10mm or 13mm internal bores. But if the distance between the tap shank and pipe is only 13-140mm is it ok to use a flexy and means it may curl up/over a bit, or will it split?
