Flipping plumbers
12 Sep 2004
I have just had my central heating renewed, at the same time as I'm rewiring the property
Having emptied the dormer bedrooms, I lifted all the 8*4 boards to get easy access for both myself and the plumber
The plumber got there first and run the main flow and return the length of the property( from one side of the bungalow to the other ), and has teed off for all the radiators both up and down using front to back runs
It looks a really neat job but has caused me some grief
I have tried to avoid the pipes were I can but find it impossible to do this 100%
Were the cables and pipes cross, he has stayed high on the joists and I have gone as low as possible
What can be used to shield the cables from the heat off the pipes
all i can say is be careful were u screw/nail the boards bak down. last year when we got a new boiler in i put a screw thru a pipe but b/c i used a drill i didnt realise til water was comin out the kitchen ceiling
yo could have used
from tlc
cheers breezer, nice illustration, but what would you do if that cable had to turn 90 degrees (with the proper allowance for min radius etc) , and cross undeneath the pipe?
I would give it as much clearance as possible, but if it wasnt touching and a couple of inches away, i'd be happy.
And I would drill joists so cable was always 50mm/2in below top, so I did not need metal plates above it. Pipes have to lie on top, but cables feed through so you can put them lower. Weakens the joist less too, Though that is a bit moot if it has already been notched along the top.
Forget not, heat rises and your cables are underneath. A couple of inches (I mean 50mm) should do it.
will keep the gap as wide as possible and try lagging just for peace of mind
