Fluorescent Lights hunting/scrolling..
21 Jul 2007
Existing 4ft fluorescent fitting in the garage (an unheated garage) appear to be hunting/scrolling in appearance. They dont flicker, but just seems to scroll/roll (tumbling) inside. Sorry, unsure on technical term for it.
A 240v at Live/Neutral on terminals, which i would have thought a loose neutral would cause this, or maybe the cold?
Currently isolated lighting circuit until it can be rectified
Any ideas?
Nothing to do with the starter ( if you can take it out once lit you can proove this).
The cause is the cold. Leave it running for a few minutes and it will return to normal.
Thanks for the replies, thanks awarded.
I was unsure, its one of them stumping things that you never see. I did suspect it was due to the cold, and not being enclosed etc.
Happens on electronic ballasts a lot. My shop is entirely lit by t5 tubes and see it a lot especially on cold tubes.
starters can be very temperamental. Also try the electronic starter, they can prove better
As I said in post 3 it is nothing to do with the starter.
Electronic starters give cleaner starting but won't stop strobing due to the cold.
I have cured the problem in the past by changing the starter, that's why I said to try this first. Easy if it works but might not
The electronic ones actually do operate better in cold environments where the standard ones can be affected.
It sounds like his is describing the tube trying to start and almost getting there. I would either try the electronic ones, or (if its Tamlite change the thing to a decent make)
wikipedia said:
New fluorescent lamps may show a twisting spiral pattern of light in a part of the lamp. This effect is due to loose cathode material and usually disappears after a few hours of operation.
If one reads the complete accunt of the fluorescent lamp there are so many variations it is impossible to give an answer without knowing exactly the system used.
One major problem is the fluorescent lamp is a combination of tube and control gear which can take many forms. In the main the effect you see is no problem electrical wise although it may cause a problem for some people.
This is becoming a real problem with our rules on discrimination where firms may be forced to change their lighting system because one employee. As far as I am aware LED lighting does not have the same problem but the government drive for so called energy saving lighting has caused problems for some people and firms employing them.
As already said in the main caused because the tube is too cold but in real terms not much can be done to stop it.
