Ford Fiesta Rear Wiper (again)
30 Dec 2003
Worcestershire
Mine decided to pack up (1993 Fiesta 1.1) again. I first tried the common remedies - jiggling the multi-stalk and cleaning/easing the bootlid hinges all to no avail. With the ignition on and the multi-stalk in the back position I tried a bulb between the copper boot tabs and earth - got power, the bulb lit up. Having removed the bootlid trim, I similarly tried a bulb between the incoming motor plug and earth and likewise the bulb lit up. I next wired the wiper motor directly to a battery charger and it worked. So it must be the plug unit. I cut the wires and remated them via a little wiring block and lo and behold back in business.
So, I just thought you all would like to know that the wiring plug to the wiper motor is another suspect.
Hmmm...thanks for that. I've been having the same problem with my escort and couldn't work it out - I'll check it.
