Hi All,
I have some damp caused at least in part by a concrete path in the alleyway to the side of my house.
I want to dig a french drain but have read you should keep this away from the bricks but dont see how you could do this? I was going to do it in such a way that the gravel was against the brick?
Also is how much diffefrence does adding a perforated pipe make? I was not going to bother doing this as I am not dealing with large volumes of water, just the fact that the bricks never dry out.
I should add that I do not have rising damp, but the outside is around floor level and the bricks just inder the floor are very damp which has caused old joists which were in direct contatct with the walls to rot.
What I am trying to do is to reduce the damp below the dpc rather then stopping moisture rising, which I think a French Drain would help with.
