Quick question:
woke up this morning to find we had no running water (central Scotland - think it got to -10 last night).
Found one running tap, in the utility room. This runs at full mains pressure.
The mains comes in through the utility room and feeds that sink, then goes up an external wall (the pipe is on the inside but behind plasterboard).
From there I *think* the first place it feeds is the bathroom. Nothing in the bathroom works.
So to me that says the pipe is frozen somewhere as it goes between the sink and the bathroom.
I intend to pull down the plasterboard (it's in a cupboard) and see if I can thaw the pipe, assuming it hasn't burst.
I've also turned off the water mains at the stopcock as I'm at work all day.
My question is this:
assuming the pipe has frozen at the point I think it has, what is the best thing to do? Should I leave the pipes exposed to the rest of the room and let the room heat keep the pipes unfrozen, or should I lag and recover? As it's an external brick wall that the pipe is attached to I know it will get very very cold and so don't know if lagging will help in extended periods of cold.
