Galaxy 60 Advice
3 Sep 2011
Lincolnshire
Hi all new to site but need some info on a Galaxy 60 ver 1.18
I have been asked to look at a system in a night club .It is not used for intruder security that is a separate system maintained by others. The old system is used for monitoring exit doors in the event of someone being ejected by doormen or to monitor others being let in unaware.
I have replaced one of 4 key pads hat had been damaged and panel fuse.The problem is that when a door is activated the system goes into alarm but does not display the zone id on 5 exit doors .Only one is identified out of 6 . I have the managers code but no engineer code.
If this were a panel in a high risk situation I would not be messing with it but because it is low level would like to have a go.
I have engineers and user pdf any advice would be gratefully received.
check to see if the zone (circuit) is programmed correctly
go into view zones, and have a look at the status of the circuit, when door is open/closed
Oasis
