    Dismiss Notice
Gap between basin and pedestal
Discussion in 'Plumbing and Central Heating' started by jlawsonuk, 15 Feb 2007.
  1. jlawsonuk
    jlawsonuk
    15 Feb 2007
    6
    Thanks Received:
    Country:
    Due to shrinkage etc etc, I have a gap between the bottom of the basin and the pedestal in my bathroom. I'm guessing that this means the basin isn't getting as much support as it really needs (i.e. none from pedestal, just the wall it's attached to)
    Should I try to fill the gap with something and if so, what would be recommended?
    cheers!
  2. 62945835
    62945835
    11 Feb 2007
    30
    Thanks Received:
    London
    Country:
    how big is the gap?
    lift the pedestal up against the basin so its supporting it, then pack at the bottom and silicone it
  3. Sponsored Links
  4. jlawsonuk
    jlawsonuk
    15 Feb 2007
    6
    Thanks Received:
    Country:
    The gap is about 3mm or so. Pedestal is built into a mini shelf-type thing that hides the pipes, so raising the pedestal will not be easy. I was hoping to be able to do the packing between the basin and the pedestal.
  5. 62945835
    62945835
    11 Feb 2007
    30
    Thanks Received:
    London
    Country:
    3mm?
    just silicone it because once the silicone has gone off it will support it
  6. Sponsored Links
  7. jlawsonuk
    jlawsonuk
    15 Feb 2007
    6
    Thanks Received:
    Country:
    Yes, certainly no more than 3-4mm or so. If silicon can cope then I'll just do that.
    cheers!!!
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
