garage window frame material
26 Nov 2005
Denbighshire
i feel quite confident about making a new frame for my garage window but i do not want to sound like a wally when i go to the timber merchants
sizes aside what exactly should i ask for
any help would be great
i dunno,wood,brick,plastic?
give us a clue on sizes?etc,depth&width.is it going to be a fixed pane of glass?
not bothered about the sizes at the moment i just want to know what to ask for to make a wooden window frame to take a pane of glass no openers . rebated or something else
well,you could use some 3x2 prepared and a bit of 1"x1 1/4 prepared or summit like that,screw the 4 bits together with some pva nail on the the baten (theres your rebate)install glass and do a putty bead,make sure you treat and prim all timber before fixing.
You just ask for the frame sections and cill! They come ready shaped - just cut to length, M&T the joints and your done.
Avoid trying to router the stock 4x2 softwood. It most likely will end up twisting all over the place
