Garden Fence Preserver
14 Jan 2012
Tyne and Wear
Hi All
I will be erecting a new fence around my garden made out of scaff boards - these are to be planned to remove the rough faces. Will be using clear preserve
Question is: which is the best preserver to use on the boards?
Also I assume that the whole board would be covered not just my face
Total face area is @ 40sq/m each side ie 80sq/m
Any hints / guidance would be great
The bottom board (assuming you are running them horizontally between posts) will need the most thorough treatment, because it will be wettest during rain, and damp most of the time where it is close to, or touching, soil or foliage.
The topmost surface as well because it has no protection from rainfall.
Fences are mostly made of very thin timber which doesn't rot much, its thinness means that it dries out as soon as the sun shines on it, and during rainfall it is thoroughly wet, so there is hardly any time when it has the slight dampness that promotes rot. However your scaffold boards are thick enough that they will be slow to dry out.
Most fence treatments leave a waxy water-repellent film, but for anti-rot and insect preservation, you need poisonous chemicals. The spirit-based treatments penetrate better than water-based. You can stand the ends of the boards in a bucketful so it soaks into the end-grain, and apply several flowing coats by brush onto other surfaces. If you stack the boards (or lay them in a plastic-lined trough) any run-off or drips will not be wasted.
You really need to treat the boards before fixing, when you can do all surfaces.
I've taken to this sort of thing:
https://www.wickes.co.uk/Wickes-High-Performance-Exterior-Preserver---Woodland-Green-5L/p/170778
https://www.wickes.co.uk/Ronseal-Total-Wood-Preserver-Clear-5L/p/164254
https://www.wickes.co.uk/Ronseal-Multi-Purpose-Wood-Treatment---5L/p/147142
https://www.wickes.co.uk/Wickes-Shed+Fence-Preserver-Red-Cedar-5L/p/170774 (on clearance)
Also the Cuprinol products.
The outdoor ones usually contain a decorative colour (keep stirring or shaking as it sinks in the can) and a water-repellent. Clear ones are sometimes intended for interior woodwork that will be stained or varnished, and not exposed to the weather. Outdoor ones may smell somewhat while the solvent evaporates.
older builders will remember Cuprinol Green wood preserver. The original seems to be discontinued, probably because it was too poisonous.
If you look at the labels and the data sheets, you will usually find that they contain an insecticide (for wood-borers) and a fungicide (for rot). Chemicals that are not water-soluble will resist being washed away, once dry.
If you are using wooden fence-posts, they will certainly rot. Stand both ends in a bucket of preserver. The worst rot will be just about ground level, where the wetness from the ground meets the air from above, and gives ideal conditions for fungus to grow.
Concrete posts, or spurs, do not rot. You will appreciate this more when you do your second fence.
Thanks John - as you rightly summised the boards are to go horizontally. Think posts will be wooden so will lokk at your recommendtions
