garden lights
20 Jan 2005
I have a garden lighting system that uses 8 only 4 watt lamps I have broken 2 of them :oops: can I replace them with 8watt lamps
Pepi1 :
breezer said:
Thank You, but could you please explain why
We have no way of knowing anything about the system All it is is a converter run fom the 240 volt mains and gives out 12 volts AC and has 8 lights with 4 watt lamps It is a kit set and has no instructions
Pepi1 :confused:
8 lamps @ 4 watts = 32 watts.
6 lamps @ 4 watts = 24 watts (you broke 2)
2 lamps @ 8 watts = 16 watts
16 watts + 24 watts = 40 watts
as you said it is a set.
sets are usually made as cheap as possible (another story) but the transformer (you said "converter") will usually be rated at the total lamp load of the set i.e 32 watts.
I know you are in NZ, but here is an example. in the UK we can get a set of 4 garden lights for £9.99 (thats about 23 NZD)
