Hello,
This is my first post, hope you can help.
We are currently having a new kitchen fitted in our 40+ year old house, this entails moving our gas cooker approximately two feet.
To keep within the law we contacted a Corgi Registered engineer to do the job. He arrived and examined the situation and told us that
ALL the existing (steel) pipe work which runs inside the cavity and through the house will have to be bypassed with copper pipe running outside the house. We had a new central heating boiler fitted 3 years ago, fitted by warmfront and also a new multipoint heater fitted during the same year by a local registered gas fitter. Neither mentioned any problems with the existing pipe work.
Can you enlighten me as to the correct legislation regarding this matter. At present the system has been tested for leaks and passed. If this is the case then every house on our road has the same problem.
Regards
Richard Green
Regards
Richard Green
