K
KillingTime
(Three questions about insulation.)
I'm in the process of pulling up most of my T&G woodchip floorboards because they've been flooded (not by me).
I've added 170 glass wool (Knauf) insulation on the ground floor, just wondering about the void between the GF ceiling and the FF floor.
1) I suppose it makes sense to insulate this space, but what about the requirement of the insulation to breathe?
The air gets to the GF insulation from below becuase I've suspended it between the joists with perforated plastic.
2) And what about all the electic cables running in this space. I've read other peoples posts on this and the given advice is to lay the cables on top of the insuation, but I can't do this bacause they all run through holes in the joists. Not enough slack to pull the wires up over the instaltion. There's not just one or two cables, there are loads, and they criss cross everywhere.
3) Lastly, is there any advice about making glass wool insulation water proof? Most of the flooding has come from the 1st floor bathrooms. I notice that when they have flooded, the water runs across the top of the plasterboard ceiling below and spreads out while it soaks through.
If this happens again (unlikely as I'm fixing the bathrooms too) the glass wool insulation will soak it up like a sponge. This has to be bad.
How do other people insulate near / under their bathrooms?
Many Thanks.
Many Thanks.
