Hi
I have the above boiler in a bungalow and I need to re-route the hot water supply pipe from its current route through the loft to under the floorboards as currently it takes about ten minutes (no exaggeration) for the hot water to get to the shower. I therefore deduced that I needed to isolate the cold water supply (or is the technical term feed) pipe.
The cold water feed into the boiler has a brass isolation valve (like a tap) below it at floor level, but it is stuck open. At the point where the pipework meets the boiler there is (according to page 53 of the installation and servicing manual) an isolation valve, but after I have turned it 90 degrees it hasn't stopped water flowing out of the hot taps in the bungalow. How do I isolate it? I could turn off the main stop cock entering the bungalow, but it's 3 feet below the floorboards in the hall and I'd rather isolate just the boiler for now so that we can still flush the toilet, etc.
Have I done something wrong?
Any suggestions, thanks.
Simon
Simon
