Hi all,
I am new here and this is my first posting. Apologies for the length of my post.
This boiler is about 25 years old and has been in service continuously. We had a contract with British Gas initially until a few years ago they ended the contract as some of the spares were no longer available. Fair enough. Fortunately all has been well boiler wise since then until now.
For a few weeks my pilot light would go out but would normally stay lit once reignited. It no longer stays alight when the gas valve button is released. As it was such an old boiler but very reliable I decided after looking at forums like this to replace the thermocouple. I could only get a universal one.(900MM). I have never attempted any repair to it before for safety reasons. However, it would appear from comments here and elsewhere, it could be undetaken as a DIY task.
I have managed to remove and replace the TC after a bit of a struggle.
On testing I am in a similar state. Trying to reignite the pilot will result in a flame or no flame at all.
I rechecked the instruction on the cover and it tells me to switch everything on and see that the controls are set to demand heating. I duly switched everytning on and set the controls to continuous. Trying again I get the same results. I did switch the gas supply of at the mains for extra safety precautions and wondered if there could perhaps be an airlock (if thats possible). We cook using a gas oven with no effects after switching off the gas.
Is there any check I can do to test my repair or is the gas valve assembly faulty. If that is the case then I will invest in a condensing boiler.
I would appreciate any help/comments.
Thank you.
Thank you.
