Hi - I have a small section of floor that is screed.
small = 1400 X 340 mm.
The front of the screed is 23mm below the desired finish hight. The screed is not level and falls away evenly to a hight at the rear of 35mm below the desired finish hight.
I wonder what the best way to affix a section of 18mm exterior ply to this screed would be.
Most the products I have found come in quantities way oversized for this sort of problem.
So far as I can tell a glue would be insufficient.
It needs to be solidly stuck as it will form a section of an subfloor onto which a solid oak floor will be laid. So drying time is a factor too.
Cheers.
Cheers.
