    Dismiss Notice
Green sticky goo in light switches
Discussion in 'General DIY' started by The Stanton Man, 26 Jun 2003.
  1. The Stanton Man
    The Stanton Man
    26 Jun 2003
    9
    Thanks Received:
    Country:
    There is a green sticky goo inside all my light switches. it looks like it is being created in the earth wire . What is it and what can i do about it?
  2. Sponsored Links
  3. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    i could be wrong, but it sounds like your earth wire is corroding, is there any damp?
  4. cobweb
    cobweb
    28 May 2003
    92
    Thanks Received:
    Country:
    breezer is right. You have copper oxide residue. There must be damp in the wall somewhere close to the box.
    It's not a great problem in its self but could lead to the earth wire breaking and then you'd have no earth!
    If there is enough "slack" cable you could disconnect the mains fuse and then strip back the earth to unoxidated wire and reattach.
    You might also consider finding and curing the damp as this will affect the walls too.
  5. The Stanton Man
    The Stanton Man
    26 Jun 2003
    9
    Thanks Received:
    Country:
    thanks for the advice, however,the green stuff is in all the light switches not only ones on outside walls. To add a twist to the problem, the earth wires on the 30 amp ring main, cooker or shower circuits are not effected :confused:
  6. cobweb
    cobweb
    28 May 2003
    92
    Thanks Received:
    Country:
    The 30amp ring is most likely newer than than the lights and socket rings so has not had the time to oxidise yet.
    Especially if the house is an older build.
  7. Andy Velcro
    Andy Velcro
    7 Mar 2003
    49
    Thanks Received:
    Country:
    Do you remember Ghost Busters :eek: !! Just a thought. :D
  8. The Stanton Man
    The Stanton Man
    26 Jun 2003
    9
    Thanks Received:
    Country:
    So Andy, you suggest i get a white boilersuit and strap an old vacuume cleaner to my back, rather than calling in an electrician :LOL:
  9. The Stanton Man
    The Stanton Man
    26 Jun 2003
    9
    Thanks Received:
    Country:
  10. Sponsored Links
  11. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    just a thought, it may also be a low voltage on the earth cable (there shouldn't be but for a cable to turn green so quick)
  12. The Stanton Man
    The Stanton Man
    26 Jun 2003
    9
    Thanks Received:
    Country:
    how do i check if there is low voltage on the earth cable :?:
  13. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    i am not sayingthere is, it just a thought, but unfortunately since you asked, you had better get an electrcian in.
  14. The Stanton Man
    The Stanton Man
    26 Jun 2003
    9
    Thanks Received:
    Country:
    well people thanks for your help i think its time to call in an electrictian :(
  15. loftus75
    loftus75
    11 Dec 2002
    75
    Thanks Received:
    Country:
    It's likely the green sticky substance is nothing more than washing up liquid or some other solution used to ease the cables during wiring. Many electricians used to use this to ease the wires through the conduit, whether it's a good idea or not is debatable. While it's messy so far as I am aware no one has had a fault as a result of this. The only thing is, over time it may turn black, but it's harmless. The give away on this is, it's on every light switch.
  16. Scoby_Beasley
    Scoby_Beasley
    1 May 2003
    1,881
    Thanks Received:
    50
    Durham
    Country:
    I agree loftus, ring main 2" up from skirting no prob. Light switches 3' from ceiling, hard work.
    I was told to use fairy, you can do soooooo many more wires with one bottle !!!! :D :D :D (Or was it pigs, am I on the right web site ????!!!!)
  17. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    my question to thatis why only the earth wires, and there is no conduit mentioned (which is why you may use washing up liquid.
    are the cables to your sockets in conduit?
Loading...
Share This Page
