Hi hope someone may be able to help.
I have Greenstar 30CDi.
When I turn on the boiler it gets to 88 degrees within 2 minutes and the burner on indicator light turns off and the temperature increases to 101 degrees and then slowly drops to 72 degrees when the burner indicator light turns on again and the above process repeats itself. It take approx 5 minutes to complete the above before repeating.
The outlet water pope is hot and the inlet is always cold.
I'm thinking that the pump may be on the out as it is not taking cold water in to prevent the boiler from reaching the 'auto turn off' temperature?
I only have 3 rads turned on and they are a little warm.
Any thoughts on what is going on?
I appreciated any advise you can offer?
