Have a Potterton Netaheat 22 boiler - working fine as far as I know. Have a mini tank in loft for CH etc. Few months back started getting gurgling noises from boiler, figured air in system so bleed rads which resolved for a bit.
Meanwhile, upstair (loft room) rad was turned down (half way) as we don't the room much. After a while the top of the rad was cold so opened the rad fully. However, still cold on top. After 2 weeks entire rad was cold, despite bleeding every few days air seems to collect in it still! I am able to removed the valve completely with NO WATER coming out...so presume it's sludge in it..perhaps due to turning down - wish i hadn't now? Any help on this? Do I need to get a proff in to remove the rad and replace or clear it?
Then this morning, we were woken with a screeching noise that wife said seemed to come from boiler - I checked and seemed to be coming from the pump....decided to turn off in case. Then thought..hmm haven't bleed that rad upstairs for a while and did this along with bathroom rad. I think I turned off and on pump (Grundfos) using the switch that I can't see (as it's against a wall)! and put heating on. everything seems to work...all rads that were working are ok (no loft one still isn't) and no screeching noises so far for last 6 hours...
So....should I be worried about this screeching noise in the morning...could an airlock produce this noise from a pump?
(sorry about the lenght of this post...I'm verbose and can't help it)
