halstead ace 100
2 Oct 2009
Hull
i have been to a house where the halstead ace 100 combi boiler is leaking on the dhw flow switch, the flow switch has two pink wires. after a closer look when i turn the hot tap the spindle expand and leaks water from the spindle.
i have taken the manifold out hoping a oring would be worn, unfortunately i was told the whole manifold needs replacing. does anyone know if a service kit is availble or the nut where the spindle expand is availble as a spare part. thanks
If you asked in the CC then someone might be able to suggest a source of bits.
Tony
