Halstead Finest Gold Combine Boiler
8 Dec 2007
London
Recently I have notice my combine is in problem, whenever I put the heating on, when I turn the hot water tap upstairs to have a shower, my combine will be in faulty mode, what that mean is the unit is in fault. I normally switch the main switch on and off, this will resolve the problem. However it did not do it last night, the heating was never on, but whenever i turn the hot water on, combine is turn into faulty mode. Help, no hot water , I feel cold :roll:
Your combine is not one of the best quality!
Its difficult for me to guess whats wrong with your combine.
You may need a competent local boiler engineer!
Tony
They're called combi's by the way.
If the boiler fails during the self-test after switching the power on, there are very few things which can be causing the problem. The most common needs no parts at all to fix, but does have to be done by a corgi engineer.
Fan venturi requires cleaning or sensing tubes need clearing replacing. A corgi job unfortunately.
