First of all you should know that I know nothing about central heating or boilers.
Here is our problem:
We have an 8 year old Halstead Quattro boiler which prior to us installing 2 x Mira 415 showers in May last year seemed to work perfectly i.e CH & HW
During the installation of the showers the PCB on the quattro had to be replaced.
Since then we are unable to take a shower OR run taps (upstairs or downstairs) without the water eventually running cold. CH is always ok.
There seems to be no pattern to this apart from we seem to be ok first thing in the morning when the CH has not been on for long. Anytime from 8.00 in the morning until 8.00 in the evening it can be a lottery - sometimes the water is hot. Sometimes it is stone cold. *There is no pattern**
Since May we have spent over £300 on the following parts:
PCB
Diaphragm
+ labour
We have had 3 Corgi registered engineers take a look at it and each one has diagnosed something different. The latest diagnosis was that it needed to be cleaned and the 'heat exchanger' swapped!
We do not want to have to replace the boiler in we can help it (funds are tight) but it looks as though this may be the only option. How many more Corgi engineers are we going to have to try???
Some things I have noticed to aid troubleshooting:
We invariably have our CH on and it is fine
The green lit is always lit (but does not seem to be 'firing' when water is cold)
Pressure is always between 1 and 2 bar
Cold water problem applies to taps upstairs and downstairs (as well as shower) *even when showers are not being used*
Any advice welcome
PS Is there anything I can do to get a final, conclusive verdict on the problem EG British Gas???
PCB
Diaphragm
+ labour
Any advice welcome
