Has my Y-plan valve actuator failed?
25 Jul 2012
Berkshire
I've got a BGMVSP-23 actuator on a Y-plan system. I recently replaced the old mechanical room thermostat with a new digital one that combines the time programmer and thermostat in one unit. When I couldn't seem to get the new unit to get the boiler and actuator to do the right thing I started measuring with a multimeter and and found that when CH is high (230V), the output from the orange wire on the actuator only goes up to 85V.
Also, whatever the status of CH or HW (white and grey wire), the actuator only switches between either the mid-position (HW and CH) or CH only.
Well, actually, I HAVE managed to get the actuator to go to the HW only position, but I can't recreate the situation. So the valve itself seems to be fine. Is the above indicative of an actuator where the electrics have failed?
Unfortunately I can't really test the system with the old timer and thermostat setup as I had a new boiler fitted at the same time and some other wiring changes done.
