Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
isar he30 keeps goin off at will, lcd displays a 0 and 3 horizontal lines. usually works after switching off then back on but sometimes takes a few goes. been told it could be the pcb but as im not a plumber need 2nd opinion
3 horizontal lines means its overheated,check system pressure ok,pump, poss slow,if it does it when on DHW could be phex restricted,check non trv rad approx 10% boiler capacity.
sometimes the 3 lines can mean a pcb the big one at the back to the display pcb has had a communication error.
there is a way to check and thats to rehome the connection.
Over heat should be a H A code on the display "Temp in H e/X > 100c"
as per ideals Engie book
if this happens when the boiler has been idle its not overheat but double check the fault code i am in hull at ideals factory for training so i can and will double check
