I've repointed and decorated my fireplace, and want to use as a proper open fire again.
However, at present the "floor" of the fireplace is uneven (hardcore I think) and the concrete at the front does not "return" to the sides - I want it to return about 250mm to each side.
Furthermore, the concrete to the front is "flush" with the floorboards - we are having 15mm engineered timber boards put down, hence want to raise the concrete above this, and then tile this and the inside with some slate tiles.
Can anyone suggest the best way to do this? additionally, where the returns would site to the sides of the fireplace, I assume I can't concrete over these - could I put down some MDF to the same height as the concrete to form a level base upon which to tile?
Many thanks.
Many thanks.
