the boiler is working no heating luke warm the light on the boiler is not on for burner but all the rest are pilot light etc i have a switch on the tank that says auto or open what should it be onChrisR said:DOes the heating work, etc etc etc? More info the better.
kath64 said:the boiler is working no heating luke warm the light on the boiler is not on for burner but all the rest are pilot light etc i have a switch on the tank that says auto or open what should it be on[ChrisR said:DOes the heating work, etc etc etc? More info the better.
/quote] but the radiator down stairs hasnt worked for about 6 month
the pump is working the boiler is working just the burner light isnt coming onPaul Barker said:But in the interiom is it low on water or is the pump not working? Or is theior an air lock because you just hjad a job done which you haven't told us about.
all the lights are on pilot,fan,boiler just not lighting it does light up for about 5mins, then goes of as though its got up to heat, sorry a woman doesnt know muchGasman1015 said:If the burner is not working, how can the boiler be working.
Have to agree with chris, your not making sense.
Try one question and answer at a time.
No, not having a go, just trying to help.l
its an electronic pilot doesnt stay on all the timekath64 said:all the lights are on pilot,fan,boiler just not lighting it does light up for about 5mins, then goes of as though its got up to heat, sorry a woman doesnt know muchGasman1015 said:If the burner is not working, how can the boiler be working.
it hasnt fired up for abou 1 hour nowGasman1015 said:You have two circuits, water and heating, does the boiler work for more than five minutes on heating the radiators.
sorry last time it broke down i had 6 plumbers round they didnt know what to doGasman1015 said:I can see this going on for ever, you do realise that I will die eventually.![]()
Just try one next time.kath64 said:last time it broke down i had 6 plumbers round
