Hedge Cutter Required
26 Feb 2005
Gwynedd
I think I need a quality petrol hedge cutter, one of those that extends up and over so I don't have to risk life and limb every time I need to do a customer's overgrown hedge.
I seem to need to do some pretty tough hedges, not the usual privet, so I need one that'll handle some quite thick branches/stems (did a beech hedge today and some stems were maybe 2 3 cm across).
I could also do with it being versatile enough so that I could change the head on it for say, a strimmer attachment.
Who can recommend a make/model?
Just found these - any thoughts?
Mitox
Thpps
Efco
UNI
TIA
Have a scout round and see what the hire shops are using. They like quality and reliability.
I know I keep on rambling about Stihl, but I bought an HL95 extended reach / variable angle hedge trimmer (4 mix engine) - what a grand bit of kit it is (£550). They also have the attachment machines too. Domestic use = 2 years, trade use = 1 year warranty. Very important, that - if others are going to use your gear.
John :)
Interesting stuff. What about cutting diameter?
Is second hand likely to be knackered? If so, how would I tell?
Thanks for your help.
Usually if a two stroke engine has compression it has some life left in it - I pop the exhaust off and have a look into the cylinder for jammed piston rings :idea:
Reputable shops will have some traded in gear with some sort of warranty but I'd avoid auction stuff. Its in there simply because its goosed - especially local authority stuff.
My local supplier is Gustharts.....could be worth a look.
With the extended reach trimmer, its vital that the oscillating trimmer head and bevel gear have been greased - a new head costs £150. The Stihl grease tubes actually screw onto the greasing hole, which is handy.
John :)
As mentioned Stihl are the dogs, but only worth shelling out for if you'll be using more than once a week. They are fairly simple to maintain and parts are readily available.
Tanaka can be considered a poor man's stihl, if only for occasional use, although I know gardeners who use them day in day out and put them in for a service once a year.
I have an efco strimmer which is very well built, it's an oldie though, don't know what their new stuff is like.
I have an old efco strimmer too, and I can't figure out how to upen up the spool to replace the line. Could you help?
