I have a Villager kitchenia make of wood burner with back boiler heat output of I think only 9000BTU
I currently have no loft, cylinder or roof cold water tank.
I want to fit something like a twin coil cylinder with the bottom coil for later use when connected to solar panels.
The twin coil cylinder can be fitted in the room above the wood burner.
The main bedroom has 1 radiator and the size is 200cm x 40cm (ish)
The guest bedroom has 1 radiator and the size is 100cm x 60cm (ish)
The bathroom is downstairs and there is a towel rail and the size is 100cm x 40cm
The lounge / dining room is downstairs and there is 1 radiator in the dining room and the size is 150cm x 70mm (ish)
Should I have an unvented twin coil cylinder with correct coil for a wood burner, or a vented twin coil cylinder with the correct coil for a wood burner or consider a thermal store?
Some comments from others include:
Unvented cylinders may be allowed as Newark manufacturers of unvented cylinders have confirmed this. IE: the unvented going on a
wood burner this would have to be checked over by building control before installation as a wood burner would be classed as an un controllable device.
Also a friend had this to say: I have spoken to John at Oso cylinders who we normally use for our twin coil unvented cylinders. He has said that you could only use their cylinder for a woodburning or soild fuel back boiler if you have some way of controlling the temp of the water coming from the back boiler. The problem being the over heating of the cylinder.
He assures me all the other manufactures of unvented twin coil cylinders will tell us the same. If the back boiler currently has no temperature control he said it maybe worth talking to the manufacture of the back boiler to see if they can suggest anyway around it.
