Help me identify this broken pipe- water leaking along the external wall
22 Nov 2017
Hello
I have urgently have to change this broken pipe but dont know the name of it and what tools are needed to fix it . Its external pipe that comes from the kitchen .At the moment water runs along the walls instead to the drain. As Im complete newbie , I feel overwhelmed by the choice of various pipes in Diy stores so I would be grateful for links to budget friendly options like B&Q, Selco or Screwfix with items needed for this job. Thank you
It's 40 mm ( 1½") solvent weld waste pipe.
It's likely you'll have to replace the section running into the mortar around the gully.
https://www.screwfix.com/p/floplast-solvent-weld-waste-bend-92-5-black-40mm-5-pack/5234v
https://www.screwfix.com/p/floplast-solvent-weld-waste-pipe-black-40mm-x-3m/23406
https://www.screwfix.com/p/floplast-sc250-solvent-cement-250ml/14295
If you have a hacksaw then use it to cut the new pipe or
https://www.screwfix.com/p/rothenberger-plasticut-42mm-manual-plastic-pipe-cutter/58207
Take care not to damage the stub of pipe coming through the wall or you'll end up with a much bigger job. Dry and clean the stub of pipe coming through the wall before using the solvent weld on the new bend.
Replace it all with compression... elbow and coupling and some pipe... won’t look as streamlined but you’ll be able to take it apart again in the future and won’t risk it being damaged beyond future repair... also easier to do as a diy repair!
